U-Bahnstationen in NRW/Ruhrgebiet
2 Antworten2'278 AufrufeGestartet von realeric ·
Ich kenne einige aus Dortmund und dem Ruhrgebiet habe da 3 Jahre gelebt
https://www.google.com/maps/place/Dortmund-Stadthaus/@51.5079625,7.4689243,3a,75y,90t/data=!3m8!1e2!3m6!1sAF1QipP7fsA3rF8Y9sCAWtD_6DdCbFB0_zl4-Mxs1BUe!2e10!3e12!6shttps:%2F%2Flh5.googleusercontent.com%2Fp%2FAF1QipP7fsA3rF8Y9sCAWtD_6DdCbFB0_zl4-Mxs1BUe%3Dw203-h152-k-no!7i4032!8i3024!4m13!1m7!3m6!1s0x47b91760bff07a11:0x427f28131548750!2sDortmund!3b1!8m2!3d51.5135872!4d7.4652981!3m4!1s0x47b917608ad09909:0x11a0ad3b4333e212!8m2!3d51.5079628!4d7.4689248
https://www.google.com/maps/place/Saarlandstraße/@51.5053737,7.4592953,3a,75y,90t/data=!3m8!1e2!3m6!1sAF1QipOLEj473N_vM6YOJJRGsIwRfnBkniJsqkSxpM31!2e10!3e12!6shttps:%2F%2Flh5.googleusercontent.com%2Fp%2FAF1QipOLEj473N_vM6YOJJRGsIwRfnBkniJsqkSxpM31%3Dw152-h86-k-no!7i5333!8i3000!4m13!1m7!3m6!1s0x47b91760bff07a11:0x427f28131548750!2sDortmund!3b1!8m2!3d51.5135872!4d7.4652981!3m4!1s0x47b919dec861f405:0x202539a7d86cc5cd!8m2!3d51.5054102!4d7.4597409
https://www.google.com/maps/place/Polizeipräsidium/@51.5007556,7.4589428,3a,75y,90t/data=!3m8!1e2!3m6!1sAF1QipNiC98-MUEKWrGRfTOEPbhr3ZlFnvJhOD_hJbHw!2e10!3e12!6shttps:%2F%2Flh5.googleusercontent.com%2Fp%2FAF1QipNiC98-MUEKWrGRfTOEPbhr3ZlFnvJhOD_hJbHw%3Dw203-h114-k-no!7i5312!8i2988!4m13!1m7!3m6!1s0x47b91760bff07a11:0x427f28131548750!2sDortmund!3b1!8m2!3d51.5135872!4d7.4652981!3m4!1s0x47b919d9b784e86b:0xb0df83ff7933a8cc!8m2!3d51.500707!4d7.4591884
Essen
https://www.google.com/maps/place/Bäuminghausstraße/@51.4791501,7.00378,3a,75y,90t/data=!3m8!1e2!3m6!1sAF1QipPvBSF91Rn4vR6Lk6zaNb7RYS31KDIrSVPr-Z7y!2e10!3e12!6shttps:%2F%2Flh5.googleusercontent.com%2Fp%2FAF1QipPvBSF91Rn4vR6Lk6zaNb7RYS31KDIrSVPr-Z7y%3Dw114-h86-k-no!7i3968!8i2976!4m13!1m7!3m6!1s0x47b8c2b796abf639:0x6a00e111a4ad2c9d!2sEssen!3b1!8m2!3d51.4556432!4d7.0115552!3m4!1s0x47b8e81ececdcc29:0x846e27fc6f242974!8m2!3d51.4789892!4d7.0034596
Auch dieser Bahnhof ist gut geworden
https://www.google.com/maps/place/Altenessen+Bf/@51.4834065,7.0092185,3a,75y,90t/data=!3m8!1e2!3m6!1sAF1QipME18meqsMU9CqJRqacqgeKhiAiYCFYKRYumndW!2e10!3e12!6shttps:%2F%2Flh5.googleusercontent.com%2Fp%2FAF1QipME18meqsMU9CqJRqacqgeKhiAiYCFYKRYumndW%3Dw203-h152-k-no!7i3968!8i2976!4m13!1m7!3m6!1s0x47b8c2b796abf639:0x6a00e111a4ad2c9d!2sEssen!3b1!8m2!3d51.4556432!4d7.0115552!3m4!1s0x47b8e81a0de7383d:0xd4aa21e58ce4c1fe!8m2!3d51.4838517!4d7.0087704
Nett ist auch der Hirschlandplatz und HBF
https://www.google.com/maps/place/Hirschlandplatz/@51.4544515,7.0094805,3a,75y,90t/data=!3m8!1e2!3m6!1sAF1QipNUj7er1psCEEGbEXrGg128R_64rWVJGzAIeD3X!2e10!3e12!6shttps:%2F%2Flh5.googleusercontent.com%2Fp%2FAF1QipNUj7er1psCEEGbEXrGg128R_64rWVJGzAIeD3X%3Dw152-h86-k-no!7i4032!8i2268!4m5!3m4!1s0x47b8c2b7b5b3dedf:0xef8d7cc6cca8f99f!8m2!3d51.4544515!4d7.0094805
https://www.google.com/maps/place/Essen+Hbf/@51.4503741,7.0128902,3a,75y,90t/data=!3m8!1e2!3m6!1sAF1QipMOSqbw8OFek5TAyi6sbJRkHVlKFuoC_vtgHkIr!2e10!3e12!6shttps:%2F%2Flh5.googleusercontent.com%2Fp%2FAF1QipMOSqbw8OFek5TAyi6sbJRkHVlKFuoC_vtgHkIr%3Dw203-h304-k-no!7i1365!8i2048!4m12!1m6!3m5!1s0x47b8c2b7b5b3dedf:0xef8d7cc6cca8f99f!2sHirschlandplatz!8m2!3d51.4544515!4d7.0094805!3m4!1s0x0:0x7d6e4de5f957ffcf!8m2!3d51.4504103!4d7.0128749
Welche U-Bahnstationen kennt Ihr aus der CH?
Ich Tierspital
https://www.google.com/maps/place/Tierspital/@47.4025596,8.5530959,3a,75y,90t/data=!3m8!1e2!3m6!1sAF1QipM05xPHMYgKwiWgFg79njGzniAUZrneZG6hvGdJ!2e10!3e12!6shttps:%2F%2Flh5.googleusercontent.com%2Fp%2FAF1QipM05xPHMYgKwiWgFg79njGzniAUZrneZG6hvGdJ%3Dw203-h114-k-no!7i3264!8i1836!4m5!3m4!1s0x479aa081c3c2a42d:0x7f62d779a76ac465!8m2!3d47.4025739!4d8.5530678
h-max697 Beiträge
In der Schweiz gibts, mit Ausnahme der M2 und M1 in Lausanne keine U-Bahnstationen... Aber doch einige Tiefbahnhöfe die einem etwas an U-Bahnstationen erinnern.
Die Stationen Zürich Tierspital, Waldgarten und Schörlistrasse mit dem Tunnel zwischen Milchbuck und Schwamendingen wurden in den 70ern gebaut. Es war eigentlich der Pilotbau zum Projekt Tieftram Zürich, welches vorsah, die meisten Innerstädtischen Tramlinien unter den Boden zu verlegen. Also Sozusagen ein Hybrid zwischen Metro und Tram.
Dazu wurden z.B. auch am Schaffhauserplatz bereits begonnen Zugänge und Aushebungen für künftige Stationen zu bauen. Im Zürich HB waren bis dahin ebenfalls erste Bohrungen und Zugänge erstellt worden. Am Flughafen Zürich war schon der komplette Rohbau fertiggestellt.
Leider hat das Zürcher Stimmvolk das Projekt an der Urne abgelehnt und das Tieftram verschwand in der Schublade.
Der Pilotprojekt Tunnel zwischen Milchbuck und Schwamendingerplatz dient heute als Tramtunnel, ca. 2013 wurden die drei unterirdischen Stationen saniert und neu ausgeleuchtet. Interessant: die Plattformen dieser Stationen liegen eigentlich "falsch" angeordnet! (für die Tramtüren liegen sie auf der falschen Seite). Deshalb kreuzen die Trams jeweils bei der Tunneleinfahrt von Rechts- auf Linksverkehr und beim verlassen des Tunnels wieder auf Rechts 🙂
Die Aushöhlungen und Zugänge am Schaffhauserplatz wurden in den 80ern als Strassenunterführungen teilgenutzt. Anfang 2000 wurden die Zugänge und Unterführungen wieder zurückgebaut.
Ein Teil des geplanten Tieftrambahnhofs im HB Zürich wurde dann doch ausgebaut, zusammen mit der Station Zürich Selnau. Beide werden heute als SZU Stationen ("Üetlibergbahn") genutzt.
Am Flughafen Zürich wurde nach der Versenkung an der Urne der Rohbau vorerst als Tiefgarage genutzt. Später wurde daraus der heutige Bahnhof unter dem Flughafen, wobei - glaube ich - die Streckenführung noch leicht angepasst werden musste, und die Röhren vergrössert wurden, damit auch Doppelstockzüge verkehren können.
Ansonsten fallen mir spontan noch die Bahnhöfe Bern RBS Bahnhof, Bern Tiefenau, Locarno FART ein, die in der Schweiz an U-bahnstationen erinnern 🙂 wobei es die beiden ersteren wohl auch nicht mehr lange geben wird...
Hier mal eine Mitfahrt in der U18
