Max. FTP Download Speed on VDSL
8 Antworten2'346 AufrufeGestartet von aydin1954 ·
Sorry for writing in English but my written German is bad. You can answer in German though as I have no trouble reading.
That said I got VDSL 1st of September. They are still "optimizing" hence some disconnects and hopefully come October should be rock solid. Or so I hope
Now I did the ADSL -> VDSL because I download a lot from my p2p server in France that sits on a 100/100 Mb connection.
Right now I get around 950kb/s download speed on FTP. I was hoping for around 1.2 mb/s seen that before on 5k ADSL was around 300 kb/s regular and 700 kb/s with compression (Flash FXP Z-Mode).
Compression does not bring anything on VDSL for whatever reason.
So anyway I was curious on what speed others get.
interesting and puzzling...
on ADSL5000 I had max. FTP download with one session at 700 kb/s with compression and 350 kb/s each with two sessions with compression.
With WDSL I have max. 950 kb/s with one session BUT 2 x 950 kb/s with two sessions!
Willy Thunder20 Beiträge
I'm able to download from a FTP-Server in France with 2588 kb/s. I see no problem, but maybe you are just too far away from the next DSLAM. Or your Server is capping you at 950kb/s ??
nanocool324 Beiträge
Try to download something from ftp://mirror.switch.ch. They have one of the most powerfull server I know. More you will shurely not get out of your server in france.
aydin19545 Beiträge
I'm able to download from a FTP-Server in France with 2588 kb/s. I see no problem, but maybe you are just too far away from the next DSLAM. Or your Server is capping you at 950kb/s ??thanks for the answer. The server is a leased one and it is connected to a 100/100 Mb line. I have Filezilla FTP server on it and I am not limiting (myself). So guess is not that... I am wondering if Swisscom is capping me at the moment (I am in the first month).
aydin19545 Beiträge
Try to download something from ftp://mirror.switch.ch. They have one of the most powerfull server I know. More you will shurely not get out of your server in france.thanks I tried and I do reach indeed about 2.15 Mb/s but seen the speed of the server in France... I have to figure out now where the bottleneck is.
aydin19545 Beiträge
OK after some investigation I found out that the provider of the server in question does cap each connection running over 32 MB of transfer size to 10 mbps.... so 1.25 Mb/s in optimal conditions so 950 Kb/s is about right /emoticons/default_sad.png
which explains why I can also get two and probably more parallel transfers going at 950 Kb/s.
aydin19545 Beiträge
and I now found a nice solution .... multi-thread FTP using 3D-FTP client I reach 2.5 Mb/s downloading files in parallel. Has also a very nice user interface. /emoticons/default_biggrin.png
If you want a free one then also Filezilla FTP client does it too.
Nexus2k826 Beiträge
This sounds like OVH or where are you hosting ? /emoticons/default_wink.png
Sheppard82 Beiträge
Go in FlashFXP to the Preferences (F6), Connection and set the TCP/IP Puffer on 256kb Down and Up.
Is the speed not better, then you have a bad routing to the Server for one thread and you must use a multiply-thread-Client..
leechftp --> max 20 simultant threads
PS: Swisscom doesn't bandwidth throttle.
