EBU empfiehlt den Einbau von CI+ bei HDTV-Empfängern
7 Antworten1'893 AufrufeGestartet von Icetiger ·
IcetigerThemenstart877 Beiträge
Nach den TV-Herstellern und den Verschlüsselungsfirmen ist nun auch die Europäische Rundfunk Organisation (EBU) auf den "CI+ Zug" aufgestiegen...
EBU - HDTV Receiver Requirements
(Tech 3333 - März 2009)
1. Scope
This document represents the minimum HDTV receiver requirements of EBU members (the broadcasting organisations) and has been discussed in detail with DIGITALEUROPE (EICTA) representatives. Media industries developing stand-alone receiver (set-top boxes - STB or integrated receiver decoders - IRDs) or receivers with integrated digital televisions (iDTVs) are encouraged to comply with this set of requirements in order to allow interoperability between EBU Members’ broadcasts and the receiver device.
9. Content Management
9.1 Common Interface (CI)
Mandatory for STB size receiver and IDTV with screen-size bigger than 30 cm diagonal, optional two CI slots.
Optional for small receivers such as USB-sticks or plug-in PC cards.
Not required if CI+ implemented.
9.2 CI+
Recommended one CI+ slot, optional two CI+ slots.
9.3 Analogue HDTV/SDTV component output
If Y Pb Pr outputs are available then the receiver shall support the DVB FTA_Content_Management_Descriptor information as specified in section 9.7.
9.4 HDCP on HDMI
Shall be controlled by the DVB FTA_Content_Management_Descriptor information as specified in section 9.7.
9.5 HDCP switchable (via menu in STB)
It shall be possible to enable and disable HDCP for content with no usage restrictions through a user set-up menu. See section 9.7.
9.6 USB, LAN access to audio/video data
9.7 FTA content management according to signalling by FTA content management descriptor
For SDTV broadcasts no restrictions shall apply.
Note: This section follows the principles of ETSI EN 300 468 V1.10.1; however further definitions are made for the management of HD content.
The FTA content management descriptor provides a means of defining the content management policy for an item of content delivered as part of a free-to-air (FTA) DVB Service.
9.7.1 Semantics for the FTA content management descriptor
The content management descriptor is defined in EN 300 468 V1.10.1 Section 6.2.18.
9.7.2 Fundamental requirements for HD content management
The interpretation on how to apply the functionalities of the content management descriptor is currently under discussion. This document will be updated in due time.
Quelle: http://tech.ebu.ch/docs/tech/tech3333.pdf
Da bin ich dann auf die Kundenreaktionen gespannt, wenn zum Beispiel der Spielfilm "Titanic in HD-Ausstrahlung nach drei Tagen nicht mehr angesehen werden kann oder das Überspringen von Werbung nicht mehr möglich ist dank CI+......
Und vor allem wenn der Export der Aufnahmen nicht mehr möglich wird!
Na toll. Damit ist es offiziell von der Politik abgesegnet. Soviel zur freien Boxenwahl.
Habt ihr wirklich was anderes erwartet.
Was hat der Kunde eigentlich für einen Vorteil von CI+?
Können mir die geldgeilen Säcke in Hollywood mal erklären?
Ich nenne so etwas "unterstützende Massnahmen zur Vergrösserung potentieller Raubkopierer". Der ehrliche, zahlende Kunde wird immer mehr gegängelt. Irgendwann wird es einmal einen "Chlapf" geben und die Filmindustrie das anbieten müssen, was der Konsument will.
Die Analogie zu den seinerzeitigen Music-CD's, die mal liefen, mal nicht - und verseucht mit Rootkits waren, liegt auf der Hand. Heute gibts legal Bezahldownloads, zum Teil ohne DRM. Wer hätte das noch vor 5 Jahren gedacht?
Für meinen Teil vergesse ich CI+ Anschaffungskosten - ist kein Kaufargument für einen Fernseher, Receiver, etc. Die Inhalte kann ich mir immer irgendwo besorgen. Sobald dann mal ein ehrliches Angebot der Filmindustrie mit Mehrwert angeboten wird, dann können wir wieder über das Bezahlen reden.
absolutjoy496 Beiträge
Angeblich soll der Content schneller zu uns kommen (da uner Kontrolle). Wir werdens sehen, jemand muss ja noch übersetzen (lassen).
Mir ist es eigentlich egal, ob ein Film nach drei oder sechs Monaten im TV kommt. Da is mir meine Wahlfreiheit viel wichtiger.
Wenn ich einen Film möglichst schnell sehen will, sauge ich ihn mir aus dem Netz, da sind sie früher verfügbar, die Quali ist Klasse und legal isses bis jetzt auch noch (rapidshare und co.)
